Is this solder ok for battery lugs ? How far will 8 OZ go ? also it says you dont need flux, should i get it anyway ?
Thanks
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Don't waste your money on lead-free solder. It's a PITA to use. I've been soldering for over 45 years and I hate the stuff. Use regular 60/40 solder instead. And be sure to get resin core solder and not acid core. Acid core is for use on plumbing.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
Ok,I do have a radio shack near me, ill check there.. Should i hammer crimp the end a bit after im done soldering for a little extra protection
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
NO.
Hammer crimp is useless. It's a horrible connection, the solder itself will be stronger then the wire.
Yeah i knew the hammer crimp alone was garbage,, I tend to over think everything i do..Thanks for the help
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   1 Member, 0 Anonymous, 1310 Guests (See full list)
