Do u think I could hair trick on one 18?
bassman619
I suggest a smaller subwoofer/s, either a 15" or two 12" ones. With a height of only 19", minus 1.5" for 3/4" wood on both top and bottom, you're only left with 17.5"H to really work with.
The cutout for the sub isn't 18" though.The cutout for the sub is 16.69" so with 17.5" to work with he will be fine.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Yea cutout is about 16.5 and gasket diameter is 18.5...ive used sub calculators and I keep getting different answers..138" of port and 2.4 ft^ of port displacement 17.5h x7.75 w and another is telling me 100.3" of port ..17.5 x 5.75 and 1.6ft ^ port displacement
You need trunk space to get groceries and shit...bitches love groceries
if you Can get 10 cubes you should do 2 15s.. in a walled box in a Lil Car you'll hair trick. unless I'm reading something wrong.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
If it's in the trunk it's not a wall. IIt'saalsovery ttough to do a single 18 or dual 15s in the trunk. Build skills will need to be top notch and count on building in the trunk
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
But then id have to do two sa15s..to be able to push it without gettin a new amp..I dont want to upgrade power because id have to probably do an extra battery and a new alternator ..mine is only 220a peak
At or above 1500rpms does 220a of current..if I did 3000watts rms to do two sundown x12s plus whatever id run for the highs im sure id have to upgrade batteries and alternator right? I got an optima (shhh dnt laugh) works better than wet cell. I wanted to murder lows so thats why im doing the x18 more cone area than 2 12s and more cone than the 15 I had before. Listen im worried about the port.. the calculator is telling me I need 134" of port ..this would make the port over 7 inches wide.. is that okay..? I thought 5.75 w ×17.5h would be fine thats 1.6ft ^ of port displacement leaving 6.8ft^ of airspace before driver displacement
so is or not a wall? i thought i read wall. could be wrong. 220amp can push a lot of power
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Yes it is possible with an 18 and probably atleast 3k rms. You cant just throw a box in and expect hair tricks though. Alot of times cabin modifications have to be made to hold pressure and minimize flex.
  • Who's Online   0 Members, 0 Anonymous, 679 Guests (See full list)
