95legwagon Posted March 18, 2014 Report Posted March 18, 2014 Thanks for the replies, but as stated. My alternator is fine. And yes your alternator does determine charging voltage. its called a voltage regulator. 15 volts is just what XS calls for at a temp of 50f (obviously the engine will warm up and not be 50 for long). and btw starting voltage is what the voltage is with the car off, get it, its the amount of voltage used to START the car and charging voltage is with the alternator producing a current to the battery, and for your info a alt does charge a battery. If your battery is barely charged enough to start your car and you let it run for 15 minutes, guess what your alt will charge the battery. I though you guys would be smarter, I dont need a lesson on the things I already know, would like experience from someone with this battery. replys like that wont get you very far on this message board......just sayin. i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
TrentonLong Posted March 18, 2014 Report Posted March 18, 2014 1.) Don't have to act like a dick. Been there and done that. Does not get you anywhere. Just makes you look like a asshole. 2.) If you had lets say a Mechman alt it would charge around I think 14.4v but you can get a voltage booster module like Steve has on both is cars. He has his set to 15.0v. It depends on the alt but yes your battery is charging.
Noel989 Posted March 18, 2014 Report Posted March 18, 2014 Race cars don't use alts?? That's entresting Build Log - http://www.stevemead...-cruiser-el-pt/
Amart88 Posted March 18, 2014 Report Posted March 18, 2014 All of my XS batts rest at 12.87v always did. My alt charges at 15.2 cold and drops to 14.6-14.9 hot. I don;t see your problem. A 12 volt battery will not rest higher than 13v. Anything over that is residual. My 2005 s10 blazer build. 4 zcon 18's walled.
ParDeus Posted March 18, 2014 Report Posted March 18, 2014 Ok, back to dirt racing, please. Sutliff, when your friend is ready to get serious about making some horsepower, pm me. We have a few hundred dirt guys we build for, including someone you might of heard of with the last name Bloomquist, lol.
Jhunt94 Posted March 19, 2014 Report Posted March 19, 2014 I have a D3400 too and I'm pretty sure what you're experiencing is normal. I have a Mechman alternator and at start up my battery charges around 14.3V and as the alt and battery warms up then it will charge around 13.7-14.0V. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
