JEFFYBOI Posted March 31, 2014 Report Posted March 31, 2014 At what voltage should I be worried? Was listening to some tech nine and today my Stinger volt meter dropped down to about 12.8 being the lowest. Typically it sits about 14.2-14.5V at Idle on start up. It is wired to the amp, so this is the voltage my amp is seeing BTW. Im just worried im getting to low. opinions? "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS
SnowDrifter Posted March 31, 2014 Report Posted March 31, 2014 12.8 ain't nothing to worry about. I typically don't even worry until low 11s. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
pioneerforlife Posted March 31, 2014 Report Posted March 31, 2014 12.8 isn't to bad. As long as its above 12 you are good to go. ideally I would wanna stay above 12.6 so 12.8 is ok. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
rockFord_Expedition Posted March 31, 2014 Report Posted March 31, 2014 12.8 is fine for short bursts. Check it with a DMM to be sure though. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
SnowDrifter Posted March 31, 2014 Report Posted March 31, 2014 If you have any question about voltage drop, consult the manual for the voltage range of your product. Don't stray outside of that range -- high or low and IMO you shouldn't need to worry about it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
P4killer_ Posted March 31, 2014 Report Posted March 31, 2014 Youll get alot of dif answers here.. First you should check to make sure the volt Meter is reading right with a dmm. After that. Personally below 12v or so on music is sketchy for long periods ie. Longer than 15 20 sec. 12.8 is right around battery resting which means your maxxing out the alt and starting to dip into battery reserve.. which is fine. Some ppl will say buy 10000 more bats and 5 alts below 14v is crazy. Others will say as long as it doesnt go into protect idc.. Etc. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
matt14 Posted March 31, 2014 Report Posted March 31, 2014 I had a stinger meter in my yukon. Was dead on with my DVOM. Played full tilt and was .3v off. When I wired to .35ohms and full tilt, 3.0v off. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
P4killer_ Posted March 31, 2014 Report Posted March 31, 2014 3.0v off is alot... Mine is spit on tho. But 3.0v is waaay off. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
matt14 Posted March 31, 2014 Report Posted March 31, 2014 3.0v off is alot... Mine is spit on tho. But 3.0v is waaay off. Read 14.1v at the meter.... multimeter read at teh amp was 10.2v. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
hdorre Posted March 31, 2014 Report Posted March 31, 2014 I don't like to go below 12.8 (batts rest at 12.78).. and refuse to for my alt and batts' sake. Is it necessarily "bad" to? Depends on how you look at it. Your drop isn't horrible, but Id personally want much less. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
