Voltage drop, when should i be concerned?
At what voltage should I be worried? Was listening to some tech nine and today my Stinger volt meter dropped down to about 12.8 being the lowest. Typically it sits about 14.2-14.5V at Idle on start up. It is wired to the amp, so this is the voltage my amp is seeing BTW. Im just worried im getting to low. opinions? :unknw:
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
12.8 ain't nothing to worry about.
I typically don't even worry until low 11s.
12.8 isn't to bad. As long as its above 12 you are good to go. ideally I would wanna stay above 12.6 so 12.8 is ok.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
If you have any question about voltage drop, consult the manual for the voltage range of your product. Don't stray outside of that range -- high or low and IMO you shouldn't need to worry about it
Youll get alot of dif answers here..
First you should check to make sure the volt Meter is reading right with a dmm.
After that. Personally below 12v or so on music is sketchy for long periods ie. Longer than 15 20 sec. 12.8 is right around battery resting which means your maxxing out the alt and starting to dip into battery reserve.. which is fine.
Some ppl will say buy 10000 more bats and 5 alts below 14v is crazy.
Others will say as long as it doesnt go into protect idc..
Etc.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
I had a stinger meter in my yukon. Was dead on with my DVOM. Played full tilt and was .3v off. When I wired to .35ohms and full tilt, 3.0v off.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
3.0v off is alot...
Mine is spit on tho.
But 3.0v is waaay off.
Setup:
Xs D3400/ Xs XP3000
3.0v off is alot...
Read 14.1v at the meter.... multimeter read at teh amp was 10.2v.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
I don't like to go below 12.8 (batts rest at 12.78).. and refuse to for my alt and batts' sake.
Is it necessarily "bad" to? Depends on how you look at it.
Your drop isn't horrible, but Id personally want much less.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
