sharkshit55 Posted March 31, 2014 Report Posted March 31, 2014 so i have a jensen power 4. ch amp for my speakers. i have a run of 0 going to the back and 4 gauge to the amp. oh and 0 ground. so i didnt have a y splitter for the rca cable so i used the line out to go back into the input. but the channels that i did that with the sound is super low. Could my output be filtering out my power. And if this is case when i get my sub installed will this be a problem. Should i get a splitter for the the sub also. Or is all my problems from using my output to go to my input Looking to buy hdc3 and sq2200 bundle. let me know
john253a Posted April 1, 2014 Report Posted April 1, 2014 Also check what voltage input setting you are on Make sure you are 400mv-4v or low lever
n8ball2013 Posted April 1, 2014 Report Posted April 1, 2014 You really shouldnt run a signal from an amp back into itself THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted April 1, 2014 Report Posted April 1, 2014 You really shouldnt run a signal from an amp back into itself Correct. The line out, will need its OWN gain setting. Your seeing 1/2 voltage. That is one ODD fucking idea man....lol.... Split the original signal in. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
RooTxBeeR Posted April 1, 2014 Report Posted April 1, 2014 I dont get how you are running a 0 awg run to the back, then 4awg to the amp, as well as 0 awg as you stated. What exactly are the wires running to your amp? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Rich Schenk Posted April 1, 2014 Report Posted April 1, 2014 If you don't have enough preouts on your head unit use a y cable splitter to split signal before amp. Or buy a new head unit with 3 preouts. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
sharkshit55 Posted April 2, 2014 Author Report Posted April 2, 2014 at time i didnt have y splitters. i just did it for the time being. but would the weak power be seen if i run my sub amp off the the mids amp output. should i just split everything from the source.... I dont get how you are running a 0 awg run to the back, then 4awg to the amp, as well as 0 awg as you stated. What exactly are the wires running to your amp? im runing 0 to the back to a block for 2 amps. they amps only take 4 Looking to buy hdc3 and sq2200 bundle. let me know
