Terminal question.
I got the xs battery and I think it was the 586 posts (they're both the same size) and my terminals that are connected to the battery cables are two different sizes positive is slightly bigger so you don't put it on the negative.
I know what he is talking about.
The positive stud is always larger on the stock batteries. So the stock terminal is usually too big for aftermarket batts. Won't tighten. I had the same problem.
Best bet is to get terminals that will fit the XS studs.
Something like this style may work.
http://www.sonicelectronix.com/item_36370_Xscorpion-BTRG.html
The positive stud is always larger on the stock batteries. So it is usually too big for aftermarket batts. Won't tighten. I had the same problem.
Ahhhh.. i had no idea.
I just cut all the leads, and did the EYELET thing........
Take pics so we can see what you are talking about
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
