JoshxKret Posted April 5, 2014 Report Posted April 5, 2014 So my build is going to be 4 15's in a ported box, but my budget is $350 for the subs. Any help on some good subs for under $87.5
Amart88 Posted April 5, 2014 Report Posted April 5, 2014 You are not going to get any quality 15" subwoofers for that price. But there are options. http://www.sonicelectronix.com/cat_f30-121_i1236_all-car-subwoofers.html?price_max=150&price_min=50 Check them out. Personally I would save up a bit more. My 2005 s10 blazer build. 4 zcon 18's walled.
Karkov Posted April 5, 2014 Report Posted April 5, 2014 With $350 for a subwoofer(s) budget I would not attempt 4 - 15" it just won't sound that great/loud. Depends on your goals though I guess. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
BassDoctor Posted April 5, 2014 Report Posted April 5, 2014 http://www.soundqubed.com/HDS215_p_223.html Disclaimer: I have no experience with this subwoofer. The only reason that I am posting it is because it's near your budget and the AQ/SQ products I have used perform well. 04 Honda Accord LX Sedan Kenwood Excelon X998 XS Power D3400 XS Power D1200 Singer 275A alternator with factory bypass 64 sqft SecondSkin Damplifier Build to be decided
Joe X Posted April 5, 2014 Report Posted April 5, 2014 So my build is going to be 4 15's in a ported box, but my budget is $350 for the subs. Any help on some good subs for under $87.5 What's your vehicle model and max dimensions for a box?
Weigel21 Posted April 5, 2014 Report Posted April 5, 2014 With such a small budget for the subs, it makes me wonder what sort of amplifier you have, or have in mind. Four (4) 15" subs such as those HDS models listed would be asking for upwards of 2400RMS, which calls for something more than a $200 amp, and on top of that, a pretty beefy electrical system comprised of a high output alternator, upgraded wiring, and even a higher capacity deep cycle battery/power cell (if you plan to bump the system with the car off). Not going to get great results with your allotted budget. As said, probably better off with a couple 15's in a ported enclosure than (4) of them. Since SoundQubed was mentioned, perhaps a couple HDS315's, rated to take 1200RMs each, so that'd be the same power handling as (4) of the lower model. Guess if you have the room for (4), then why not, should be louder if set up properly. Still, that's going to be like 3-4cuft per sub.
jarrius Posted April 7, 2014 Report Posted April 7, 2014 IMO 2 hds15's on 2200 will work for what ever you want and you can save up and get 2 more later and another amp after electrical upgrades are done 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
john253a Posted April 7, 2014 Report Posted April 7, 2014 4x Hds2 15 On a q1-2200 $785 total And will sound good
