RooTxBeeR Posted April 13, 2014 Report Posted April 13, 2014 The sub is getting warm probably because of clipping. Hour did you set ht amp? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
MrSkippyJ Posted April 13, 2014 Report Posted April 13, 2014 single SA-8 and 1400 watts? Single SA-8, 4-ohm DVC (700w RMS). Sorry, forgot to add that part... I had a short conversation over that with Sundown and they recommended 4-ohm DVC rebuild. So that if I decide to go 2 SA-8's it'd be 1400w RMS @ 1 ohm. sounds good then! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
ToNasty Posted April 13, 2014 Report Posted April 13, 2014 I know this is asking too much, as I've read over and over .75 net. But would it be okay with 1.16 cu ft?Thanks Way to big ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
xxgokouxx Posted April 13, 2014 Author Report Posted April 13, 2014 The sub is getting warm probably because of clipping. Hour did you set ht amp? The remote knob has a "distortion" indicator, the distortion indicator only goes off when I play single beats, not long notes. There's no distortion according to the meter at all. The light doesn't go off. I set my gains a quarter up, I haven't played with other settings on the amplifier really, as I don't know what to tune to yet. single SA-8 and 1400 watts? Single SA-8, 4-ohm DVC (700w RMS). Sorry, forgot to add that part... I had a short conversation over that with Sundown and they recommended 4-ohm DVC rebuild. So that if I decide to go 2 SA-8's it'd be 1400w RMS @ 1 ohm. sounds good then! Awesome! I know this is asking too much, as I've read over and over .75 net. But would it be okay with 1.16 cu ft?Thanks Way to big I've been tinkering and I just can't get it right. Tried .75 cu in, and everytime I input, it's like 40Hz+. Is there a downfall to being too big of an enclosure? I'm all ears and this is literally my first successful box built.
TheMonolith2001 Posted April 13, 2014 Report Posted April 13, 2014 Setting the gain on that amp should be idiot proof, It has a clipping indicator that many users of this forum have deemed accurate.
youngbass98 Posted April 13, 2014 Report Posted April 13, 2014 If the enclosure is to big the you will have over excursion and your sub will bottom out 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
ToNasty Posted April 13, 2014 Report Posted April 13, 2014 Yes I the box is to big it's like having less pressure which helps the suspension. To big of a box can make the sub max out quicker ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
xxgokouxx Posted April 13, 2014 Author Report Posted April 13, 2014 If the enclosure is to big the you will have over excursion and your sub will bottom out Gotcha. Thank you! Yes I the box is to big it's like having less pressure which helps the suspension. To big of a box can make the sub max out quicker Any tips to making the dimensions work? I'm still playing around and it doesn't look good at all so far. I'm trying not to let the port go outside of the box.
ToNasty Posted April 13, 2014 Report Posted April 13, 2014 Go to Home Depot and look at there PVC. I think they have one with a inner diameter of 3.75. Put that into Torres which should shrink the box ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
xxgokouxx Posted April 13, 2014 Author Report Posted April 13, 2014 The bigger the inner diameter, the more Hz it has to the tune.... This is frustrating, I feel like I'm doing something wrong lol.
