Difference in DC Power Alternators.
Oh damn, yea sorry, I have no idea then. Maybe ask them to be sure. Because it's in different case maybe?
internals are the same. if its a 370xp its a 370xp. the case would not effect the idle that much. only thing i cna think of is becaue the alt may not spin as fast on that car at idle so it wont make much amperage since larger alts have a higher turn on. if that is why thats pretty crazy they went through to change that for every vechicle.
That's a thought. =)
Yea, I thought maybe internals could be different with different case but nvm, lol, I was wrong. =O
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Simply put, there is a difference in the stators configuration. Either the power curve peaks at lower idle output or higher top end output. Sadly, you can't always have both.
I'll chime in for a second: ideally you'd have something like a GM truck or suv with a large 8" crank pulley. However, lots of passenger cars have smaller pulleys that that, so it cuts the pulley ratio for the alt making it spin slower. Couple that with low idles speeds to save gas and depending on your car, idle output can really suffer.
I'll use my own car as an example: 2003 forester, 5 1/3" crank pulley, 625rpm idle, dc390xp. I'm only clamping 10a at idle. Barely enough to power the voltage regulator for the alt. At 850 rpm, the alt has kicked on and I'm seeing around 175a from it.
Contrast that to a team mate who had the same alt, but in an suv with a bigger crank pulley than me. 8" iirc, same idle speed. He was seeing a bit over 200a at idle. While I don't have jack.
You really need to be aware of turn on speed and pulley ratios. If you really want to be slick, see if you can sweet talk a local automotive shop into using their scanner to measure your hot idle speed(don't forget to tip whoever helps you). Then on your own, measure the diameter of your crank pulley. Call up the alt company of choice, report these numbers to them, and they should be able to give you a true idle output estimate specific to your car
Ok this makes alot more sense now. Thanks for the help.
Now I have another question for you. The reason I plan(ned) on buying the DC370XP was because I'm upgrading my system to about 10k watts. I have 4 D3100 and 1 D3400 + DC270XP at the moment. Will that upgrade in alternators be necessary being that my current amp idles more than the 370 per say?
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
what 10k in power? I mean, what amp(s)? 10k RMS, actual RMS?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
So for my use is it better to keep the DC270xP
That is what you have to figure out for yourself, is it more important to have more power at idle? Or more power under throttle? I like having bigger amperage and so match batteries with my alternators to ensure I can listen at idle, play for hours, but also rev up when needed
The 370 is expensive and out of stock. Keep your 270 for now, do your upgrading etc. etc. Once at 10k if you are not satisfied then upgrade your alt if need be. You have decent battery bank, no arguing that. Whether it's up to snuff for 10k or not I am not gonna debate about. Make sure your actual wiring is up to snuff but keep the batts. and alt you got, play your 10K watts and watch voltage like a hawk, if not satisfied, upgrade.
That's what I would do. I mean you do already have good alt and batteries. just sayin
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I currently have once Crescendo BC5500 plan on getting another soon.
I'll stay with my 270 gonna install my VM-1 and tune with a DD-1 to ensure no clipping etc. If power is running to low I'll look into upgrading alternator and/or 1 or two more batteries. (Problem is I'm running out of room lmao)
Thanks for all the help fellas.
Current Build:
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
