8 10s Walled, 2008 Saab 93 - Loudest Saab
i think i will paint the side of the wall when you open the rear doors silver to try and match my car.
stay tuned for that and another addition as well.
I cut one baffle at a time if you are using a jasper jig you can stsck all your baffles amd drill your pilot hole all at once. If you have a flush trim bit you can cut one baffle and then mount it in place and flush trim out the second
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yeah...drill your pilot hole all the way through, cut from both sides
I think I've done 1.5" baffle with a 1" bit before though
can't remember what size bit I have but it BARELY made it through
Team Flex Issues
I cuy in multiple passes anyways. Two layers is 4 passes one layer is 2. Its easier on your bits and routers
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
N8, are you using a spiral upcut or downcut? or do you use something else
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
I use a spiral something. I think its an upcut.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
