8 10s Walled, 2008 Saab 93 - Loudest Saab
I have to pull 5 amps to Pull a sub. There are less bolts holding your console in than I have amps.
Same here but I have to pull the amps and my passenger seat too.
Used to have a loud truck
i guess ill keep it the way t is. but i need to take off 3/4 in from one layer 1.5 all the way around so the baffle sits in .75 more giving the sub more room to move safely.
ill finish the wall then load subs/ take out the console.
Seriously Ross?
I realize Saab guys were idiots who made stuff extra complicated, but I can literally remove my honda center console in under 3 minutes, I'm sure yours is less then 6 screws in the proper order. Don't puss out.
If I showed you what I had to do to get my 2 X 12's in my trunk (takes 2 people over an hour a sub) so grow some balls and finish it man.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Don't give it up over removing your console. Shouldn't be that hard to do. Keep pushing forward you got this.
It's like rubbing your wiener up against a sheep.
