Just a thought on batteries and charging systems.
Another thing you have to look at is the purpose of the battery. Deep cycle batteries like the xs and kinetiks etc that are aimed at car audio have been designed to be discharged and recharged over and over again. A telecom battery or a battery used in an ups are meant to be charged and hold that voltage until power is killed and then provide enough power to maintain service until power is restored, switch to alternate power or gracefully power down the hosts. These are all factors to look at.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Batteries do not store power over their resting voltage. Anything over their resting voltage is a residual charge and will be gone as soon as a load is placed on the battery.
would this be where good capacitors come into play
anyone else refreshing this page like a crackhead
Regular capacitors NO. Super Capacitors yes if you pair them correctly with the battery power you have and the amperage draw you have.
thanks nathan i know what i am doing for electrical now
i know this is off topic but will you guys ever start a line of super capacitors
I can neither confirm nor deny what is sitting on my desk
The amount and quality of lead in the battery determines the capacity of the battery. The grid pattern on the lead plates, intercell connectors, and internal design determines how quickly the battery can discharge that capacity.
For instance our 16V and 14V batteries. We have the light S version and the heavier D versions. They are the same physical size with the same internal design, but the S is lighter. Only weight to lighten the S version was to take lead out of the battery, which in return gives is less reserve capacity. You have a trade off with weight v/s capacity.
You can get more power per battery if you buss a bank of smaller batteries together, because bussing them together optimizes the internal pressure in the batteries. Now this means if you have 5 small batteries and buss them together each of those 5 batteries will individually produce more power than they each would standing by themselves. This however does not increase each individual batteries capacity.
Would LOVE, LOVE to learn more about this. Can you elaborate. More power...... as in voltage, discharge rate? Very curious.
Yeah, Lets keep this thread rolling!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
True. I always question people who "don't have voltage drop" when they run big amplifiers but only a single alternator.
This is because they have so much box rise that the amp may be seeing 4+ ohms and not putting out enough power or drawing enough current to create that voltage drop.
perfect example is my own car. I ran a DC3.5k at 1ohm on a single g34 redtop and 180 amp alt for around 6 months with no issues. My pair of XFL 12's were in a box that was 3.5 cubic feet GROSS. And according to my understanding the smaller the box the more box rise, also around tuning is when you have the highest amount of box rise too. Box was tuned around 28hz, anything low I would hold low 13's to mid 12's full tilt, the second I played above 45hz I dropped down to high 10v.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Mmmmmmmmmmm, me likey this thread :D
Keep in mind, as Nathan mentioned, batteries don't charge up to 14.4V.
They have an internal resistance to overcome which is why you need to charge at 14.4V in order to get a resting voltage of ~13V. That 1 volt or so is lost in the charging process.
Also as mentioned, caps (super) don't have this limitation and will hold power at any voltage, within their rating.
So a bank of super caps would be very helpful in the range of 13 - 14.4V to help stabilize your voltage.
:good:
Agree on the super caps comment, but running a bank of just super caps is a huge waste of money compared to building a bank of super caps that is sized for your bank of batteries. Both have their advantages and disadvantages when compared against each other, but when paired together CORRECTLY you can get the best of both worlds.
Instantaneous discharge capability. The will deliver more power individually when bussed together. Money wise it doesn't work out, but I would take a bank of 5 or 6 D680 over a single D3100 for a burp.
:good:
Good point! Any tips on how to properly match supercaps to a battery bank?
Another very good point!
Would I assume correctly that, similar to electrolytic capacitors, a bank of small caps will have a much lower ESR each then one larger cap.
Therefore the group of smaller caps can release energy faster then the single larger cap.
So the same could apply to a battery bank?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
  • Who's Online   0 Members, 0 Anonymous, 3340 Guests (See full list)
