its like 15 minutes from me. lol. But itd probably cost the same amoutn in gas.
heres the link.
http://www.cruzinport.com/
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
heres the link.
Lol the gas thing is true. Im about to check out the site :good:
god it pisses me off your all so close....
i have no one....
sad panda
Hey, hey, hey.. You have Kenny :)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Those speaker rings look like shit :peepwall:
Yea.. I kinda got screwed. Rings look like shit, and the guy who made them is a dick :/
:D
Atleast you got yours :peepwall::roflmao:
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Ok.. more little updates..
Last night, I hit up Kevin.. and I picked up 20ft of SHCA 1/0, along with 5 set screw fuse holders and a few 300A fuses. He sent me a few ninja pics of what CNF coming out with.. and I can't lie.. they look sick :D
I did some measuring this morning for speaker clearance. My goal is to NOT cut any metal in the door, as the part Id have to cut is close to the part that holds my window motor and regulator. Id rather not weaken that part of my door.
87892D57-040D-47EF-A80C-D56EF51B9F7A_zps
LMFAO so true
:blush:
I don't want my box jumping around and beating up my hatch.. So heres my little solution..
I already started working on this one.. but my car has plastic bins in the hatch from the factory, which are screwed down into plastic adapters.
48260123-0505-4BB9-A420-A586EA981C95_zps
I dont trust these adapters to hold down the weight of the box, amps, and subs, so I removed them. The first one was a bitch because I didnt have a plan. Once I got one done, I was set. Heres my method of madness lol
F79F645B-0285-41C9-BE5A-2678C0F145CE_zps
Well.. it worked :shrug: So, fuck it..
38E99B39-1A57-455B-A925-AA61E5CE3307_zps
These holes are accessible from under the car.. if your arm is 3 ft long hahah.. but I did see daylight at the bottom. As a result, I need to add the bolts from the top.
I could use small bolts, but I don't need shit snapping.
5750B0B1-DD33-44EB-BFF7-5FC339CBA5B1_zps
I knew it wouldnt fit, so lets take out one of my best friends..
39B06BEB-D89D-4A01-8359-05A08F3F50EC_zps
EBE510B8-B7B0-46D1-858A-C97FA0A4837B_zps
Much better.
1D0EFED9-AE03-4F47-B30A-0841592BEDC3_zps
Now, I need to get the proper bolts, bigger washers, and nuts. The washer is what'll make the most contact area with the metal of the car.
The layout will be: Bolt --> Washer --> Cars Metal --> Washer --> Nut --> Washer --> Box --> Washer --> Nut
Got washers? LOL
LMFAO so true
:blush:
Got nuts? You will be out after that.. :ninja:
Lol.. Coming from you... :D
Anyway, heres the idea.. The first hole was my test dummy, so it wasnt the best.. But I still have 5 more, which will be spot in. I formulated a better plan.
65464435-4C50-4A23-A87F-6BB1BB3D743C_zps
Im going to get a wider top washer.
CB35D53C-488F-4B99-BA56-3863FB7B1EC4_zps
This is just barely hand tightened, but you get the idea..
8926E9CC-5FB9-468C-AB3D-70C88A32E183_zps
Make believe my fingers are the false floor.. This is sorta what it'll look like.. I fucked up a little.. One of the washers that on TOP of my fingers will be UNDER my fingers when all said and done.
7061AEC2-882D-40C1-86A4-70EC8CD51289_zps
LMFAO so true
:blush:
Whered you get the beaver bit to drill that hole?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   2 Members, 0 Anonymous, 1352 Guests (See full list)
