oldsoundguy Posted April 27, 2014 Report Posted April 27, 2014 I had the ct 1400 running a HDC3 12" dual 2 ohm wired to .05 ohm daily and it slammed. Amp never got hot and sub never smelled. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
bumpinTL364 Posted April 27, 2014 Report Posted April 27, 2014 To speak to the power handling of soundqubed subs, I'm running an HDS212 on 1200watts daily (it's a 600rms 1200 peak sub) and never have I smelled coil or even gotten the dust cap warm enough to think I should turn it down or stop demoing. masterbation is free, and even saves you money.sorry but someone had to say itsorry, Jimmy...beat you to it (no pun intended) LOLDON'T get a wife. Best advice I never got, and now it's too late My build: 12" DCON in a dorm room. New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
FuriousG Posted April 27, 2014 Report Posted April 27, 2014 I had the ct 1400 running a HDC3 12" dual 2 ohm wired to .05 ohm daily and it slammed. Amp never got hot and sub never smelled. Oo I'll take the .05 ohms as a typo, but you also meant 2 C3's right?
oldsoundguy Posted April 28, 2014 Report Posted April 28, 2014 I had the ct 1400 running a HDC3 12" dual 2 ohm wired to .05 ohm daily and it slammed. Amp never got hot and sub never smelled. Oo I'll take the .05 ohms as a typo, but you also meant 2 C3's right? I was running 1 HDC 3 12" and was running .5 ohms not .05 duh sorry. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Ahmed Johnson Posted April 28, 2014 Report Posted April 28, 2014 I got the hdc3's and they are every bit as musical as the type r's i had before them. Slam way harder though
DubNDodge Posted April 28, 2014 Report Posted April 28, 2014 HDS300s are back in stock. Saw a post from Soundqubed on FB. I would personally go HDC3 and then grab another one down the road. I have had the HDS300 and I am not all that impressed going from a 2.5" coil to a 3" coil. I was slightly clipping my sdc2.5s, and when I upgraded to the HDS300s they handled the slight clipping the same as the sdc2.5s if not worse then 2.5s. Both would start to smell after 15minutes full tilt. Needless to say I had the sdc2.5s for over a year NO issues. I had the HDS300s and within two months one of my coils started to unwind. Go HDC, you'll be much more pleased. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
rsfm089 Posted April 28, 2014 Report Posted April 28, 2014 why not 2 hds310 or hdc310 or 12they called me back this morning and they have the hdc3 10s in stock
CodyLucente Posted April 29, 2014 Author Report Posted April 29, 2014 I had the ct 1400 running a HDC3 12" dual 2 ohm wired to .05 ohm daily and it slammed. Amp never got hot and sub never smelled. That's the amp i have and i wasn't sure if at 0.5 ohm if it was to much power for that sub daily i only have a 125 amp alt but i do have dual batt's so electrical is not really a problem for the amount of power that a single 1200 im using and i just bought a DD-1 so i know im not going to clip a sub to death anymore. ( *mofo 12's* cough) Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
CodyLucente Posted April 29, 2014 Author Report Posted April 29, 2014 why not 2 hds310 or hdc310 or 12 i like the tone of the 12's better than the 10's and i figured if i had a single sub that a 15 would give me more punch than a single 12 and the hdc 112's are sold out hds 312's are sold out hdc 315's are in ------ And a 15 is in stock vs the 12's Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
jarrius Posted April 29, 2014 Report Posted April 29, 2014 How any woofer sounds is all in the box man. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
