Spaekers pop on start up
2003 Chevrolet Tahoe. Bose factory head unit. Db Drive 1250 watts. 1 12" sub. Hits HARD. $330 for amp. $ 275 speaker. Tried turning the gain down on converter and thump was not Aas bad. But speaker doesnt hit as hard. Didnt try turning gain down on the amp. Assumed it would also not hit as hard.
Turning it down on the amp probably wont do anything anyway. But I don't know what else to tell you. The price on the amp doesn't meant it's great because I would take a sq1200 for 60 dollars cheaper over that. Good luck!
Turn On/Off Thump
Turn on thump can vary from a slight pop to a mind shattering, teeth rattling BOOM! This thump is caused by the audio circuitry stabilizing when power is applied. Most amplifiers and source units have muting circuitry that lasts a couple of seconds to allow these fluctuations to subside before passing a signal. However, if the amplifier un-mutes before the source unit or any other accessory, you better watch out. Here are some things to try if you have turn on thump.
  1. Verify that the amp has a good audio ground reference. (See rule 6 of the Ten Commandments of noise free installation.)
  2. Dont install the system so the amplifiers can be switched on when the source unit is turned off.
  3. If you still have thump, add a turn on delay module in line with the remote turn on wire to the amp.
  4. This concludes the section on turn on thump
http://www.termpro.com/asp/pubs.asp?ID=121
My truck does it turn off and on. I can assure you I.dont have any wiring issues. Some amps just do it like he said
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 2835 Guests (See full list)
