Can you crimp these lugs?
I purchased a few of these awhile ago with the intention to solder them. Since then, I got a 16 ton crimper. I crimped one on some 1/0 Stinger ofc and it pulled out pretty easily. I contacted who I purchased them from asking if I could exchange them for solid lugs, without the split. I was told that these are fine to crimp. I sent this pic to be sure that he knew which lug I was talking about.677.jpgHe said they crimp fine. Since then I've done 2 runs, fuse blocks, all grounds, buss bars. Basically, the entire charging system, crimping these "split" lugs. When crimping these lugs on the new wire, which is not Stinger, I couldn't pull them apart. I'm still not convinced they will last, any thoughts anyone?
No, not properly
Solder them IMO.
Long story short: Crimping cold welds AKA fuses similar metals. I've tested this several times, copper and brass lugs don't fuse - they come apart.
I would slowly but surely change em out for the shca lugz thats what I am going to do.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
i always used copper lugs and filled it full of solder and stuck my wire in there. Im not a big fan of crimping. But it should be fine, Is there anything different about your stinger wire compared to your other wire?
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Split lugs are harder to crimp. You need to bring in one flap under the other then crimp. If done right you should have no issues with them. They won't look anywhere as nice as the others, but with a little shrink over the end, they will serve their need. This is something you can readdress later when time and or budget allows for it
^^Disagree
Just because it may stay in place with a quick tug doesn't mean it's a good connection. I've tried that, crimped them with a 16 ton crimper with 0 gauge OFC wire. Wiggle it a bit and it comes out.
Tried it a couple times with various crimp settings. Even getting it down to something a hair larger than a pencil. Same result.
Conclusion I came to is because it's a mechanical connection - the lug is squeezing the wire, holding it in place vs. being fused with it. Those lugs are comparatively(vs an amp terminal or fuse holder that is designed to squeeze) thin, they can only "squeeze" so hard before they give. That's why I can wiggle them loose
While on the subject... How are you crimping these anyway? Hammer? Vice grip? Hydraulic?
Good deal
Yeah man I think your best bet would be to grab some crimp terminals, cut, strip, and re-do. Shouldn't be *that* bad :)
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
