Im looking to add some bass to my car i want to keep my factory stereo in what would be the best way to add an amp in.
Oh car is 2010 chrysler 300C
2015 F-150 Platnuim
I'd say probably one of the best ways would be to get a Rockford Fosgate 3sixty.3 or other processor that can integrate into a factory system. There's always line output converters and other modules that would be cheaper, it's all about preference.
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
... Or find an amplifier that has "High Level" inputs
Yeah....I forgot about that....definitely another good option...
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
I looked at a few line output converters but what would i use for the remote turn on
I've seen guys install a toggle switch next to the headunit
You can tap in to the fuse box it's really easy google it or checkout the 300 forums
I had a loc then went high level input from the factory head unit wasn't happy until I went low level and aftermarket head unit. I still use this mod below to turn on my amps.
26455455-298d-45bc-846d-d1c9b37514a7_zps
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
If you look up the wiring diagram for your car there should be a ignition wire either hooked up to your deck or through the cars stock amp if it has one. I've tapped into some fuses under the hood and etc. and done just fine. Mine right now is on a toggle switch that constantly has power but it works great.
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
