ohh myyy
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • 1 month later...
Time to rip out this temporary wiring job.
I had some major feedback, not alternator or engine noise.
It was there with the truck off completely.
Most likely it was caused by cheap rca's with zero shielding being ran over and under numerous power wires, and or the 360.2 just sitting on top of the 4channel. LOL
  • Like (+1 Rep) 2
So I bought a welder the other day, and went to use it last night and the feed wheel didnt spin.
So I returned it last night which is where I left off after cutting the angle iron.
Today I decided to try welding, this time the feed wheel works.
I need a bottle and some gas on it, but Im going without for now.
Not a pro at welding by any means, and all I ever did was a little bit of welding with a stick welder.
I got a big learning curve ahead of me. After all people took classes for this and have many years experience.
So here is my first weld... LOL
and amazingly it stays together! haha
grinding it all smooth
test fitting
more test fitting
some added corner supports to stiffing it up a little
I need to get a little more steel, I want to run a lip or a small raised edge along the bottom so the amps will not slide off when i set them on there before I get to put the bolts through to securely hold them.
  • Like (+1 Rep) 2
See you found a way to get all 4 to fit back there. Welds look much better after grinding them down lol, I'm sure mine would look much worse.
It's like rubbing your wiener up against a sheep.
Little more progress..
Welded the little strip on the bottom to give the amp rack a ledge to set the amps on so they dont slide off before they get bolted.
welds are starting to look a tad better, but much more prat ice is needed for sure!
The hinge idea I came up with. Using a grade 8 bolt so it should be plenty strong and welded the nut to the amp rack itself.
Should give me minimal /limited room to get under the amps for whatever reason if needed.
Hung the rack from a JL audio basket with a giant ziptie
And a couple coats of paint
Sold an alt to my friend and needed a harness to get the dummy light to turn off on the dash, Singer was the first to reply and reasonably priced ftw
amps laid out on the rack to mark the holes to drill them for bolts
Also drilled the holes in the angle iron which will be secured to the back of the wall with lag bolts
Hinges bolted on
Also pulled the batteries out the back for the time being
  • Like (+1 Rep) 4
If I backed it into my garage to get out of the rain I could have it playing in not long at all, but Im sore from all the crap I did today.
Amps just need to be tuned, and have woofers hooked to them.
  • Like (+1 Rep) 2
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
