Question about SPL sub sound
I have two HDC 3 12s running off a 2200 amp. I can get the subs to play real loud. I mean so loud that I get a ton of body panel resonance sound along with vibration sounds. I have one layer of deadener on the roof, floors and doors and MLV on the floor also. Do all of you guys hear the same thing when you have it up full tilt? To make my system sound good I need to turn the gain knob down or it doesn't really sound that great for daily listening.
Maybe I need more deadener on the roof and interior panels IDK...
I guess I need to get some demos from guys in my area so I can compare.
Kind of want both were I can turn it up loud and feel the bass slamming but not hear all the affects of it that it has on my car..
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
If you can still here the rattle you ain't loud enough. lol jk. Probably need more layers of deadener. The setup in my friends ranger rattles everything on it and even moves the doors in and out abit, but when you in it all you hear is the back window.
Does he have a solid rear window or a slider? I have a slider in my Toyota Tacoma and it makes a lot of noise. I want to get a solid rear window for it.
80prs
DC 180 alt
Volume up im not hearing anythinf else volume down you can hesr some stuff rattle.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Go down to Home Depot and buy a couple cases of ALEX Plus acrylic caulking and start adding that by the tube behind every panel. There's a guy up my way that runs 20KW+ and does mid 150's that used this method and his panels are dead quiet.
He's got a slider. His truck is the 1st time I've seen a bed flex, granted its right at the window, but still.
@ Ahmed Johnson That's funny. Its all good man
To tell you the truth I don't have any idea what the fuck I was thinking. lol
I know I wanted loud clean bass but really never expected this much flex and noise from my truck.
Don't get me wrong my system (to me) is bad ass and I have never had anything even close to this in a vehicle before. I will deal with it one step at a time.
I just ordered another 40 ft of deadener to do the roof and rear panels so I will have a couple of layers on there. I found a solid rear window at a wrecking yard and I will pick that up tomorrow and order a new gasket. That should help. Then just go step by step to eliminate as much of it as I can.
I guess I just need to keep the gain knob down when daily and then crank it up when I go to a comp to see what it will do.
I just wanted to know if anyone else has the same problem.
Oh and no I am not clipping...
80prs
DC 180 alt
I know what you mean though. I got basically the same stuff and I won't lie, I never expected it to get this loud months later. I'm happy with the shit, actually I'm fighting the urge to do more.
  • Who's Online   0 Members, 0 Anonymous, 1906 Guests (See full list)
