Do some research, find someone to help you design a new box with the spec for that driver and rebuild. Proper box makes all the difference in the world! You sir do not have that! live and learn. No biggy, we have all been there.
Chuff Chuff city bitch
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
What the ....
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
LOL these comments really had me laughing, thanks everyone for the advice/info, and it's just some mdf from lowes, I was just goofing around experimenting.
believe half of what you see and none of what you hear lol.
2003 Ford Taurus SEL
JVC KD-R520
4 JL ZR-525CSI 5.25 Mids
4 JL ZR100-CT Highs
1 18" RE Sx Dual 4 ohm wired parallel to 2 ohms
1 Kicker CX1200.1 (Bass)
1 DD S4B (Mids)
2 Optima Yellow Tops
200a Alt.
http://reaudio.com/box.php
Use this. Itll give you a cut sheet etc. If nothing else allow you to view the model and see what a box should sort of look like.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Yiur port looks to be approx 1inch x 3 inches. Giving you a port area of 3sqin. Your box looks like idk 2 cuft. 3in of port / 2 cuft of net airspace = 1.5in per cuft. A typical ported 12 box is 12-20 sqin of port per cuft.
So your a good bit shy. Generally. So in terms of a ported box its kinda choking the sub off because its too small. Like a bottleneck.
Its more like a sealed box with a large hole in it.
Either way you look at it, its not ideal
Setup:
Xs D3400/ Xs XP3000
You'd be correct if this was a 12, haha. The port is 2" wide and 4in tall, 7" deep, box is 1.4ish cubes. By the way it's a 10. :)
JVC KD-R520
4 JL ZR100-CT Highs
1 DD S4B (Mids)
200a Alt.
8" of port area isn't sufficient. Double that maybe(closer to triple in reality). The way it currently sits, the port is acting as a hole in a sealed enclosure.
It would undoubtedly sound better if you plugged it up and sealed it.
P.S. I mean these statements constructively. I truly am trying to help.
