MrLandedra Posted June 2, 2014 Report Posted June 2, 2014 Just a question a friend had asked me, and I honestly don't know the answer. I told him I would find out and let him know tomorrow, so the question is: Can you wire a Dual 4 ohm AND a Dual 2 ohm subwoofer to the same amp and have it come out to 2 ohms? If so, what are the risks, and if you can't, what's the cause behind it? believe half of what you see and none of what you hear lol. 2003 Ford Taurus SEL JVC KD-R520 4 JL ZR-525CSI 5.25 Mids 4 JL ZR100-CT Highs 1 18" RE Sx Dual 4 ohm wired parallel to 2 ohms 1 Kicker CX1200.1 (Bass) 1 DD S4B (Mids) 2 Optima Yellow Tops 200a Alt.
truthsayer Posted June 2, 2014 Report Posted June 2, 2014 No you can't get a 2 ohm load with the subs you have. Either .666 ohm parallel or 12 ohms in series. truthsayer
OrionStang Posted June 2, 2014 Report Posted June 2, 2014 So much fail. One sub will see more power than the other, it just doesn't work right. SMD Super Seller My Feedback Thread
CleanSierra Posted June 2, 2014 Report Posted June 2, 2014 The parameters of the sub are actually different as well, not JUST the voice coil impedance. The other T/S specs are different between a D2 and D4 of the same sub. Im not the one you want to try to troll. Just a fyi for you.
S15_Silvia Posted June 2, 2014 Report Posted June 2, 2014 Ok, look: I'll use the rightmost formula in the blue section. P = (V^2)/R. At a given voltage output from the amplifier, the speaker with a smaller R will consume more wattage (P). This (and the different T/S parameters as mentioned) is why wiring different-impedance drivers to the same circuit is a bad idea. Another edit: TECHNICALLY speaking, it's possible to run just one coil on the 4Ω sub and put the 2Ω coils in series on the other sub, then parallel that all together. DON'T DO IT, but theoretically it can be done. I am not responsible for damaged subs. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
MrLandedra Posted June 2, 2014 Author Report Posted June 2, 2014 Thanks guys, I'll let him know. believe half of what you see and none of what you hear lol. 2003 Ford Taurus SEL JVC KD-R520 4 JL ZR-525CSI 5.25 Mids 4 JL ZR100-CT Highs 1 18" RE Sx Dual 4 ohm wired parallel to 2 ohms 1 Kicker CX1200.1 (Bass) 1 DD S4B (Mids) 2 Optima Yellow Tops 200a Alt.
k58.cross Posted February 22, 2019 Report Posted February 22, 2019 I am necromancing this thread. I have a dvc 2 ohm and dvc 1 ohm sub of the same make/model. According to the manual the t-s params are essentially the same for both subs. I could get a final 0.7 ohm load by wiring the dvc 1 ohm coils in series to make 2 ohms, then that in parallel with the other 2 ohm coils (so parallel combo of 2:2:2). If I did this and put them in a 2x12 box I already have made and power from a monoblock that I know can handle the load, will it work or will I get cancellations? I know there's statements such as "they will get different power", but can I get the info from someone who has tried this or knows someone who tried it? I did do something similar in the past. Two Type-R 12's which were one generation apart. They were the same DVC 4 ohm, but different physical constructions altogether so the t-s params had to be different. I had no issues pounding the shit out of them.
Joshdashef Posted February 22, 2019 Report Posted February 22, 2019 19 minutes ago, k58.cross said: I am necromancing this thread. I have a dvc 2 ohm and dvc 1 ohm sub of the same make/model. According to the manual the t-s params are essentially the same for both subs. I could get a final 0.7 ohm load by wiring the dvc 1 ohm coils in series to make 2 ohms, then that in parallel with the other 2 ohm coils (so parallel combo of 2:2:2). If I did this and put them in a 2x12 box I already have made and power from a monoblock that I know can handle the load, will it work or will I get cancellations? I know there's statements such as "they will get different power", but can I get the info from someone who has tried this or knows someone who tried it? I did do something similar in the past. Two Type-R 12's which were one generation apart. They were the same DVC 4 ohm, but different physical constructions altogether so the t-s params had to be different. I had no issues pounding the shit out of them. Wouldn’t recommend it if you want your equipment to last. Cheaper to sell and buy proper drivers than go through the hassle of destroying equipment imo SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
k58.cross Posted February 22, 2019 Report Posted February 22, 2019 Why is there risk of destruction though? I'm trying to ask for a technical explanation of what happens. Like here I will try to use some logical deduction: * Assume subs are completely in phase, because time delay between the two can lead to cancelling waves. * Two 2 ohm coils will get the same voltage as the series-combo of the 1 ohm coils, since all is in parallel. However, the two series 1 ohm coils will split the voltage they get. BUT since those coils are physically fixed to each other, shouldn't that split voltage combine back up anyway? * As long as the subs are in phase and cone displacement is roughly the same, there should be no electrical or mechanical opposition between the two subs and output will be normal. * IF one sub has different cone displacement than the other, will that negatively affect operation? This question goes into fluid dynamics I think, because you're dealing with air compression systems both in a chamber and in "open space". I'm looking for answers beyond people just saying it's "common knowledge". I kinda think people are just going off of what each other has been saying for awhile, which doesn't necessarily make it an absolute truth.
