The "Battle 8s" 6th order blow-through
Naw, just use the Torres calculator to get your rear to the size you need then repeat with the front. Then make sure your design flows (sub towards the port and a smooth flow from the rear port to the front port). Of course you know nothing is set in stone about these enclosures and your best bet is to build with change in mind. That is why my box worked out so well, I built it with enough volume and in a way that I could change in case of bad results. You always have to prepare for problems and you can always make a box smaller if need be.
  • 2 months later...
finally got the 8" sub, ended up getting an atomic 8" with a 2.5" coil.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
That's crazy
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
  • 4 weeks later...
