dharris2488 Posted June 28, 2014 Report Posted June 28, 2014 Hey guys, just want you opinion before I purchase this. I want to make my setup look cleaner. This should also make my installs go much easier as well. Was thinking about mounting somewhere in the trunk. Do you think this would work? I will have (2) Q2200.1's, (1) Q4-120, and a Kenwood XR400-4 coming off it. Will have all my batteries in parallel off this as well (total of 4 batteries). What do you guys think? http://www.amazon.com/gp/product/B00GJUZUMI/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A1NZSGX8D9PVM7 Thanks 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
moredbs Posted June 28, 2014 Report Posted June 28, 2014 personally i would just order some aluminum bars, and make my own. or if you wanna pay more order some copper.
bigmizzle99 Posted June 28, 2014 Report Posted June 28, 2014 I like 'em for a pretty made solution. I saw those on a different site and bookmarked it. Get one and then show us pics! Camaro SS Build Altima build 2.0 Altima build 1.0
dharris2488 Posted June 28, 2014 Author Report Posted June 28, 2014 personally i would just order some aluminum bars, and make my own. or if you wanna pay more order some copper. I thought about aluminum and I'm sure it would work just fine... I may try this copper and see how it works out. Only thing I'm worried about is the Texas summer heat. That copper will definitely get hot. Going to order the copper and give it a go... I can always yank it and do it out of aluminum if I don't like. I figure I probably need two, one for + and one for grounds. Should make install much easier... I was going to say a breeze, but that's never the case! 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
