the Hair Tricker (trying to trick with a single 18" in a 6th order)
In for 6th results
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
CC Audio your are the man.
I can wire up just about anything and know Ohms law and all that stuff but I am also aware that wiring this thing up wrong will make the magic smoke come out and I never learned how to put that back in. Thank you for your help. I think I am going to recone it because of that 60 hz Fs. reconing to a dual 2 ohm would help it's daily life and I'll see what Dave can get out of this beast.
Single 15
6th order
This is my kind of build. In 4 vids :popcorn:
2007 Pacifica
  • 4 weeks later...
Btw. That audio ban was made by daichi. It's a good sub with a beefy 4 layer long aluminum voice coil. This will sound good tuned low. This sub was built long before audiobahn went super china. I think it's going to be nasty.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
OP info on there
your sub is the model AWIS 15
Maximum power (power handling), W 2000 RMS *
Resonance frequency Fs, 47.5 Hz
Total Q Qts 0,787
Equivalent volume Vas, l 38.2
DC Resistance Ohms 4 x 2.0
The mass of the moving system Mms, 300.4 g
Force factor BL, TM 14.2
Sensitivity dB (1 W, 1 m) 88.7
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
  • 5 months later...
Going to upgrade to an 18" now. Thinking I want a 4" voice coil woofer. I know this will start some shit but who makes the best 18" with a 4" VC? I'm going to put it in a 2+/1 6th order with the back ported to 32-30 hz and the front ported around 60 hz. Double wall everything and prob some turnbuckles or cool bent tube for bracing. I'm thinking the back will be around 6-7 cu ft and front will be 14+ cu ft. It should be nasty. Let me know you hypothesis, opinions or just bitch at me for only doing one
  • Who's Online   0 Members, 0 Anonymous, 2258 Guests (See full list)
