What fans are you guys using to cool your amps/setups
There's a thousand on newegg.....most are 3 wire, I assume that wouldn't matter
Any 2 wire ones for even more simplicity?
120mm seems the most common
Team Flex Issues
I used 8 of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200067
They are actually 4 wire. Positive, Negative, Tachometer sense wire, and control wire. But yeah, you can just use the positive and negative and it will spin at max. That's for any case fan, I've done it a few times before.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
one positive wire and two negatives... depending which ground is connected will change the speed-
would also like to add that they make more noise when mounted horizontally... which sucks... dont know if they are not ment to be mounted that way or what??? any computer guys know???
Horizontal or vertical. Doesn't matter. I have both in my case.
98 Mustang GT
Singer 320
2 12" Incriminator Death Penalties
1 SAZ-2500dv2
2 D3100,1 D3400
2 Crescendo CZ-65
SAX-100.2
Door panels by Diablo Kustomz
  • Who's Online   0 Members, 0 Anonymous, 2516 Guests (See full list)
