I don't see the need to bolt the box down in this install. With the sub's in the box its 220+ pounds. And is sealed on the front so there is no way you can even pick it up. Just saying.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
The box don't jump, just has vibration.
Pic of the setup. Amp is mounted on top of some foam and still gets a lot of the vibration.
Just supports my previous post.
But could you move the batteries to either side of the box and then mount the amp behind the box then?
Kinda was thinking this^. Now that I know the deadener won't work
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
it will stop the box from vibrating in turn your amp wont vibrate (as much)... theres obviously enough energy there to cause the vibrations hence why you made this post......
Well thanks guys. I'm going to try all things said to find what will work.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I will have to take a look at them
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Witches should scare you, they are scary. :P
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Witches should scare you, they are scary. :P[/quo
Lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Typical deadener will do nothing on a box. You wanna deaden it? Build it right. Brace it well.
I'm undecided about rubber washers. The amp has to be tightened down very tight, and is therefore coupled to the box via the screw or bolt you mount it with, which basically negates benefits of rubber washers. And if it's loose enough for the rubber washers to do anything, then it's bouncing around so much that it's actually much worse. I know it sounds great, but I guess I'm just skeptical they're the saving grace everyone makes them out to be. :shrug:
i defiantly agree with you on this one. i have never seen the real benefit based on exactly why your saying. I guess i could see some benefit if there was a way to loosely attach them without have them so loose it would bounce But properly bracing the box will stop a lot of that in the first place
