Fourth order enclosure for a single kicker cvx15 dual 4
I have a single cvx15 that I'm playing with and I have decided to build a single reflex bandpass for it. Can somebody help me out with some killer gross internal specs! I need square inch port opening and depth tuned at 45hertz as well I'm a carpenter so the build will not be hard
You need a port area of 109.6e-9homesteads, with a rear chamber of 2 bushels and a front chamber of 4 bushels.
The port length needs to be 63 barleycorns.
That is net volume not gross volume so you need to subtract the displacement of the port, walls, and the sub.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
The more drunk you get the more you will understand that post.
Basically, if you're looking to build a 4th, you're going to do it 4 times before you're right.
Those are legitimate specs for his sub.
Im pretty happy with my 4th and i only had to build it once.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Preciate the advice, but can somebody put me on with some internal gross specs that's going to be killer I need port square opening cubic inches and depth for my kicker dual 4 cvx-15? Any more specs?
You should be able to figure out those if you are a carpenter.
9-10 cubic feet, 180(minimum) inches of port and that's assuming a tune of around 48 Hz. So if you're talking about a square port, that's about a 13.5X13.5" square. With 10 cubes internal NET space, this makes your port(sharing no common walls) ~10" deep.
Port size: 13.5X13.5X10
Total port area: 182"
Tuning frequency: ~ 48 Hz
Port displacement: ~ 1.27 cubic feet
Box needs to be 4-6 cubes sealed chamber, 10-18 cubes ported chamber.
No one can give you specifics because on paper and in the vehicle are two different things. If you want a 4th order bandpass design for those subs and your car, find someone that will take the time and pay them.
Can we pay you ;-)
  • Who's Online   0 Members, 0 Anonymous, 3107 Guests (See full list)
