If a car doesn't come with rear DOOR speakers, will it have the hole?
My Camry (1999) doesn't have any speakers in the rear DOOR and I am wanting to add a third set of 6.5 speakers into my car and the only place I can think of is throw them in the rear door. Does the rear door have a hole where I can just mount in the set of speakers?
Right now I have front door + rear deck speakers.
My guess is you should be able to see if theirs a hole in the door panels
If not even if their space the panels would block the sound
Unless you do some modification to the door panels
I know the rear door doesn't have a hole in the door panel but I could easily cut a hole and put a grill over it. I'm just hoping there's a speaker hole for me to mount a set in.
Meh. I'll take the back door panel off later end of this week to check.
Yea Just checked once you see you might get some ideas on how to do it
Even if theirs not a space for the speakers you might have a place where to put an adapter to the door
Also like you said your willing to cut a hole in the panels you might be able to adapt the speaker to the panel instead of the door
If there isn't a hole in the door, you can easily cut a hole and mount a MDF spacer to it in case the hole isn't perfectly round to fit the speaker, and do like you said about cutting a hole in the door panel and mounting a speaker grill to it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
No rear speaker holes in the 97-01 models. Front doors, read deck, and front tweet spots
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
if there is a option to have a speaker in the location it will be there regardless of what model/option you have... reason being that the manufacturer will not make a die specifically for one or the other. they will undoubtedly have if for the option of having the speaker and be void if that option isnt selected-
Rear fill is pointless IMO.
Just put those extra 6.5s in the front doors. You'll be much happier
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
I like my rear factory speakers. They have good mid bass and compliment my front components nicely.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 0 Anonymous, 1384 Guests (See full list)
