Why should I run active?
Slinky
I need someone to explain to me why I should run active as opposed to passive for my mids and highs. I have (at least I think I have) all the necessary ingredients to run an active setup but I don't really see the point.
My equipment,
2 sets of Rockford T1675-S components on a Soundqubed Q4-120.
Factory deck, but I have a Rockford 360.3 that everything is connected to.
I may be switching to DD soon but thats what I have for now. Basically I don't see the point in running active if all it does is allow you to change the crossover slopes and tweak the power to each driver. I feel like using the crossovers included with the components sounds good already. Is there something I'm missing? Where's the appeal?
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
It allows you to correct defects in the response due to the speaker, if you have an RTA you can measure response to get a "flatter" response along with finding baffle defraction to get the most optimal crossovers, along with being able to run able to time align if you haven't already (Idk if 360.3 has that).
You also get to avoid the negative affects that the components in a crossover can have.
Krakin's Home Dipole Project
Components fluctuate their crossover points under loads. Not by a ton but they do, just do to impedance and power going through them. Active will always be exactly what you set the crossover points to since it is done electronically before the signal is amplified. Also in my experience you get much better response and output from speakers when ran active. Also if running active you have more control of time alignment since each speaker can be controlled.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
With no offense to you, you lack the one most important component to running active successfully, and that's knowledge. You may have the hardware, but not the software. Search that topic on this forum read up and ask questions as needed to clarify.
When your ready you wont be asking should I run active you'll be telling us what you benefited from running active and how you went about doing it.
Rolex you sicken me.
Just let me finish my pie
~ Juice
Numerous benefits. Will you notice any of them? Probably not, based simply on you asking this question.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Wow, so two helpful responses, and two complete assholes. Thanks to Krakin and Robert for the info.
DD M4
Hey prick, fuck you. You have no idea how forums work do you. Reread my post, reread your response, and then ask yourself why I think you are an asshole.
DD M4
Your welcome for being an asshole. Apparently you cant read as my first line clearly stated I wasn't trying to offend. So now I'll just say go fuck yourself I hope you fry your shit. If you think the shit your running already sound good why are you looking for someone to convince you to do something else? Seriously you douche bag, get a clue use the search key and decide for yourself
~ Juice
  • Who's Online   0 Members, 0 Anonymous, 1201 Guests (See full list)
