Painting MDF process
BIGlep
You can also resin the exterior of the box as well, and sand it smooth and do a final sand with 220-400 grit paper to remove any large scratches in the resin.
You could also fill the edges with bondo as well, dry wall mud would be the easiest to sand. Never used it on mdf myself but seems like a great idea.
Here are a few of the ones I painted, I used a HVLP spray gun on these ones.
This black box was just a quick coat, nothing to fancy just wanted to spruce it up for the chick a little before we put it in her car.1269271_686015101422300_123309686_o.jpg
A nice smooth glossy paint job on this one and the next one.
10357461_770619412972376_237895395740008
1801150_811498308884486_2761873287123309
This box was built into the car, and spraying paint wasnt an option. This was done with foam mini rollers, and lots of wet sanding between coats to keep the paint smooth!
I used FoamPro roller pads, these ones to be exact http://www.menards.com/main/paint/brushes-rollers-trays/roller-covers/foam/foampro-foam-roller-fine-finish-6-inch-10-pack-refill/p-1473853-c-8115.htm
So did you use resin on all of those excluding the first black one? The camera diminishes black paint quality but that white looks incredible. Are you using primer over the resin?
  • 2 months later...
I'm going to build my 2-18 box as smooth as that d a m man
Good luck and take pics!! :D
iirc the port radius is 6inches, the corners vertical corners of the box are a 3inch radius, and the horizontal edges around the top of the box are a 2inch radius.
No kerfing was done to make these corners either.
That white one has no screws and weighs 600 lbs. correct? All brad nails and wood glue? correct? Flawless work...
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • 3 months later...
  • Who's Online   1 Member, 1 Anonymous, 1777 Guests (See full list)
