Carpet around port??
dsw422
hey guys.. quick question..
What is the best way to make sure carpet dont try and come up when it is cut on the edges of the port??
The box is for 2 10's, port on the right side..
any special glueing techniques for area like that??
thanks guys
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
If you're setup has any kind of power, carpet/vinyl is gonna start coming up. Only way to stop it is visible brads or staples. I don't know of any adhesive out there that will hold on its own.
SMD Super Seller
My Feedback Thread
Well I would think that the best way to do it would have been to rabbit a very tiny groove around the inside of the baffle around the port to tuck the carpet into, but if you have already assembled your best bet would probably just be to use a high quality carpet that doesn't fray too bad and make sure that you apply enough glue and do it properly. You could also make a small trim piece to go around the port and hold the carpet down, but personally I don't really care for the look of those too much.
On the other hand you could always not carpet all the way to the port. I have seen a lot of people do that and leave a couple inches around it which they end up painting.
when I first started building enclosures I had this issue. I've learned you need to give the glue time to fully cure. I use both 3M Super 90 and Dap Weldwood.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
pretty low power.. about 500 watts max.. just want to make sure box stays looking good around port for a long time..
1994 Ford Bronco
Sony door speakers
You could do a trim piece and make it very tasteful. If you look up Jat4011 on youtube he build a box way back for an Incriminator 15 with a pressure fit trim piece. I looked pretty good.
Box isn't put together yet.. what size rabit do u think? i dont like the trim peices either.. and i have thought about not carpeting to the port, but then i would have a couple corners of the box where carpet would stop
im gonna use the 3m super 77.. ive used a couple times..
1994 Ford Bronco
Sony door speakers
Sry, but hot glue just don't sound very viable... but thanks anyway
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 4010 Guests (See full list)
