ProMaxx316 Posted September 6, 2014 Report Posted September 6, 2014 I can post a video if needed. The electrical set up on my truck 1994 Ford Explorer, 2/0 welding cable, Mechman 270 alt, Mechman AVBM, XS 6500 under the hood, XS 975 in the back, Flatline FL2, American Bass 350.4. Just recinly the voltage have been going from 14.2-14.4 hot and highway speeds with all audio on. When I turned on the A/C I notice the voltage getting a little funky. and the compressor was making a little noise and getting me some belt slip so no more A/C. But now even with the A/C off I been seeing the stock voltage needle bouncing around, check the avbm and voltage is going from 14.2 down the 13.5ish and back up. All at idle. When driving on the highway everything seems fine. All connection look and feel tight, check alt ground, check rear battery ground, check connections at amp and everything looks and feels ok. Any of you guys have any suggestions? I'll be uploading a quick video in a few. If it's worth building, it's worth over building.
ProMaxx316 Posted September 6, 2014 Author Report Posted September 6, 2014 Here's a link to video What you guys think is going on?: If it's worth building, it's worth over building.
GSanders17 Posted September 6, 2014 Report Posted September 6, 2014 Failing ac compressor putting extra strain on the system maybe?
Kyblack76 Posted September 6, 2014 Report Posted September 6, 2014 fuck that is odd... remove the vcm and just run it stock, and see what happens..... (can ya do that easy?) SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Tarball Posted September 7, 2014 Report Posted September 7, 2014 avbm is probably crapping out or bad connection somewhere. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
SnowDrifter Posted September 7, 2014 Report Posted September 7, 2014 This is why I hate weird ways of boosting voltage. The AVBM, MLA, even diodes. They give you some funky issues when they start to break down Unplug it and see if you still have the issue ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
alaskanzx5 Posted September 7, 2014 Report Posted September 7, 2014 Belt slippage (worn belt bad tensioner), crappy stock voltage gauge, cheap voltage meter, and of course what has already been mentioned. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
fufhubbin Posted September 7, 2014 Report Posted September 7, 2014 just a quick question. im thinking about buyin a Ho alternator (if i can find 1 for my car!) 1994 altima but if you have one and a secondary battery does ur voltage like not drop at all or something whats a healthyish voltage drop for a stock alt 1 battery ORION HCCA 10.4 2000 watts RMS 4000 watts max hifonics brutus 2600 bxi Alpine IDA -305 Digital receiver 0 gauge power wire 250 amp fuse 800 watt BUTTKICKER BASS SHAKER Kicker zx-400 amp to power buttkicker
alaskanzx5 Posted September 7, 2014 Report Posted September 7, 2014 just a quick question. im thinking about buyin a Ho alternator (if i can find 1 for my car!) 1994 altima but if you have one and a secondary battery does ur voltage like not drop at all or something whats a healthyish voltage drop for a stock alt 1 battery Make your own thread t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
ProMaxx316 Posted September 7, 2014 Author Report Posted September 7, 2014 Thanks for the replies. As of right now the first thing im trying is disconnecting the ac compressor in the theory that it might be pulling a load even when I have the switch off. I'll drive a few days and see if it still happens. If it does then I'll look into a better voltage gauge and try with avbm disconnected. I did send video to mechman to see if they have any suggestions If it's worth building, it's worth over building.
