Loaded vs. Unloaded
gckless
what i want to know, this is directed at cableguy and bbiefe, do amps have regulated power supplies on the pre-amp circuit.
if not that seems like a serious design flaw to me. that cicuit is critical and if its not we dd-1 users have been doing it wrong this whole time.
bear with me here.
if they are unregulated, then when we set gains with car off then run the engine the pre-amp will be producing more voltage to the amp and would lead to clipping. if regulated then setting gain on the amp should be done with the car off and you should attempt to keep voltage above your resting voltage when playing.
also, just because you drop below resting voltage does not mean you automagically start clipping, just means the amp is going to pull more amperage and run hotter.
edit
words are hard, see bold type for correction
dork
bear with me here.
edit
dork
you wouldnt have me any other way sweetie
bear with me here.
edit
Aren't you supposed to set your gains with the car off? That's how jeffrey did mine... Since my car will play at 13.1 for a longgg time, it only makes sense to set it at 12.8/9 then 14.0
bear with me here.
edit
you should re-read my post.
bear with me here.
edit
Not really catching your drift? But I'm eager to see either of their responses so the answer can help me understand the question. Would be sweet if Tfade would chime in with some testing aswell.
I'll also pick on the big daddy Incriminator 80.1. Note the voltage.
Unloaded.
Resistive clean
8AB4B796-C009-4E40-913C-2280240340D3-900
Resistive clippy. Notice this is the same voltage as max clean unloaded, but loaded and it's clipped to shit.
D1C5C0B7-E5CC-4685-8E37-F47AC330D058-900
  • Who's Online   0 Members, 0 Anonymous, 660 Guests (See full list)
