Show your battery terminals.
I have been doing some searching around for the perfect battery terminals. Looking for something that will accept multiple 1/0 wire with lugs on them.
What I came across was some military grade battery terminals. I dont care for the type of terminals that have a set screw in them just a fear of them coming loose. That is mainly why I like to solder wire to lugs. Link below to the Military grade battery terminals
http://www.ebay.com/itm/Military-Battery-Terminals-Boots-Set-For-A-Heavy-Duty-Dual-Battery-Set-Up-/331326370313?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d24973209&vxp=mtr
1000x75165562913907_01095201112260354596
Now show what you have done on your battery terminals or the products that you use.
Id rather have a terminal block with set screws that has way more surface area around the SAE post than either of these that have some rather thin metal.
Setscrews can loosen up, but thats called preventive maintenance and you should always give your setup a look over every few weeks.
You can always use thread locker as well.
Pioneer AVHX-5800BHS
Alt CES 200/270+
Alt CES 200/270+
I put the ones like the first set you posted on my dads truck. I loved them, but about 3 lugs is really the max that I have been able to fit on them. They are cheap too. I get them from Tony at CE Auto Electric for $6 a pop.
They are pretty thick too. They do have some meat to them.
If it was me I would go with first one that skater229 said
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   0 Members, 0 Anonymous, 1598 Guests (See full list)
