AstoSoup Posted September 29, 2014 Report Share Posted September 29, 2014 I guess this could be considered more of a general electrical question but since it applies to my head unit, I decided to post here....I hope I posted in the right place and my apologies if not. I have a Clarion VX709, 7" Touchscreen DVD head unit. In order to play DVD videos, the wire is supposed to be connected to the e-brake ground and only show video while the e-brake is applied. My passenger frequently watches movies while driving, so connecting to the e-brake is not possible for me. On my old 4" DVD HU, I simply grounded the wire and left it, allowing me to always watch video. This unit however, is different. In order to see video on the screen, the ground MUST be made AFTER the video has started playback, making it so a constant ground is no good. I have been waiting until the audio on the movie starts, then twisting the e-brake cable together with a grounded wire. This does the job, but it is a pain twisting the wire every time I turn it on and looks horrible having two bare wires hanging. My question is (and I hope it isn't a stupid one, lol), can I wire the e-brake cable through a 12v toggle switch to a ground, and just flip the switch to make the connection? Or do toggle switches only work for positive currents? I have Googled every search term I can think of and nothing has answered my question, so any help would be appreciated! Thanks! Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
audiofanaticz Posted September 29, 2014 Report Share Posted September 29, 2014 You need to wire a relay to do it for you. Link to comment Share on other sites More sharing options...
boom50cal Posted September 29, 2014 Report Share Posted September 29, 2014 Worked great for me on my pioneer. Just a switched ground. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
islandpride684 Posted September 29, 2014 Report Share Posted September 29, 2014 If the relay method does not work, you will need this: http://www.diybypass.com/products.html companies are making it harder to bypass video playback while driving.... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted September 29, 2014 Report Share Posted September 29, 2014 You can't connect it to the ground in the wire harness? I know e-bay had a bypass switch for like 15 bucks. Link to comment Share on other sites More sharing options...
bcbrassard Posted September 29, 2014 Report Share Posted September 29, 2014 The by-pass harness worked on the Pioneer APP radio I install in my brothers ranger. Get one and try it. Link to comment Share on other sites More sharing options...
CleanSierra Posted September 29, 2014 Report Share Posted September 29, 2014 You'll need a double pulse to make it work. Didn't read other comments but friend with Pioneer had to set it up to bypass that way. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
AstoSoup Posted September 29, 2014 Author Report Share Posted September 29, 2014 This may sound newbish of me lol.... but I don't even know what a double pulse is Really, all I need is something to make the connection for me instead of twisting the wires together. What type of relay would do this for me? I had my doubts about a normal toggle switch doing the job, that is why I posted here before going ahead and purchasing one. If all I need is a relay, I can manage that, just need to know which relay in particular to get.... Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
AstoSoup Posted September 29, 2014 Author Report Share Posted September 29, 2014 If the relay method does not work, you will need this: http://www.diybypass.com/products.html companies are making it harder to bypass video playback while driving.... The link provides one for Clarion as well Thanks! Looks like a pretty simple deal, three wires and it's done. It should come with directions, right? Like where to hook which wire, etc.? Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
bcbrassard Posted September 29, 2014 Report Share Posted September 29, 2014 Yes it will have directions. Easiest 3 wires to install! lol Link to comment Share on other sites More sharing options...
