Ground Zero GZPW15SPL, enclosure suggestion ?
Hi guys!
New at this forum, so if the post is placed wrong, please correct me :)
I got a Ground Zero GZPW15SPL sub, and i need a enclosure for it, but it has to be a box that fit the sub, and not the vehicle cause im changing car pretty often.. its gonne be a serious box, cause the sub's weight is 47kg (about 105lbs)
But i really dont know how big it should be.. im thinking tuned to 33hz and L port.. specs on the sub can you see here :
http://www.ground-zero-audio.com/components/com_jshopping/files/demo_products/GZPW_15SPL.pdf
Hope you guys could show me what it should look like with all messurements ect. and feel free to correct hz and everything if you have a better idea (wich i think)
Best regards
Christian H.
welcome to the right section ;) haha just being a dick
I'm on break at work so don't have access to many resources... but can start you off hopefully
start by downloading Torres box calculator
play with that, putting in dimensions and port sizes, just have fun and experiment
use the sub specs from the pdf to start, especially recommended ported volume (can't see PDF on phone)
Based on the specs on the PDF
4-4.5cubes tuned to 33hz with 15-17 sqin of port per cube.
What kind of power are you planning on running and what vehicle? Also, are you looking for daily or SPL?
This tuning is NOT for this driver. Sure, it will play, but it's not what the driver is built for. It likes higher tuning. The subwoofer itself is pretty stiff, so it would require a lot of power.
Still need to know what vehicle is it, in any case what's your next vehicle to see that the box fits both if possible.
you seriously serious about that??
they DO play lows verry nice, and they bang when they do play...also you need to throw a lot of power to them to play lows..
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
wall it with a single sub setup..
  • Who's Online   0 Members, 0 Anonymous, 5208 Guests (See full list)
