Jhunt94 Posted October 28, 2014 Report Posted October 28, 2014 The prime amps are surprisingly efficient. 4guage would be just fine on it. ^what he said. Those amps put out a surprising amount of power, but aren't power hungry so 4 gauge will be fine. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Team Bassick - Kimo Posted October 28, 2014 Report Posted October 28, 2014 My basic rule of thumb when comes down to wiring is anything over 1000 watts should be at least 1/0. 1500-2000 big three. Over 2K upgrade battery. over 2500 upgrade alternator and add at least 1 Battery. 3000+ caps and batteries (both or either) depending on applications. KIMO @teambassick http://www.teambassick.com
Slinky Posted October 28, 2014 Report Posted October 28, 2014 Lmfao!!! No way in hell you need 1/0 for a 1200 watt amp. No. fuckin. way. Unless you are doing a super long run or something, get some 4 gauge and be done with it already. As for the amp.. That rockford that was originally linked will do rated, will match your gear, and is super affordable. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Motorboat KER Posted October 28, 2014 Report Posted October 28, 2014 It also depends on the quality and type of the wire... cca, ofc
goldmouth Posted October 28, 2014 Report Posted October 28, 2014 Was thinking either rockford fosgate 4 gauge amp kit knukoncepts or stinger all supposed to be ofc
Jhunt94 Posted October 29, 2014 Report Posted October 29, 2014 My basic rule of thumb when comes down to wiring is anything over 1000 watts should be at least 1/0. 1500-2000 big three. Over 2K upgrade battery. over 2500 upgrade alternator and add at least 1 Battery. 3000+ caps and batteries (both or either) depending on applications. Why? If it needed 1/0, don't you think the manufacturer would have recommended it and made the terminals large enough to accomodate it? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
goldmouth Posted October 30, 2014 Report Posted October 30, 2014 Yea ^^ dats what I was thinking I have a 1000 watt kicker amp that only has 4 gauge terminals & I kno it'll do more than 1000 watts
RainStryke Posted October 30, 2014 Report Posted October 30, 2014 Just because a amplifier doesn't have 0/1 gauge terminals, doesn't mean it can't work with a 4GA to 1/0GA adapter. Maybe he's talking about CCA wire.
Team Bassick - Kimo Posted October 31, 2014 Report Posted October 31, 2014 Its my rule of thumb, because there is no such thing as not enough wire. 1/0 power from front to back then distro down to whatever the amp or amps take. With as many systems I have done over the year there is one thing that is apparent. IT IS ALMOST NEVER FINISHED!!!! Unless you are going full competition retarded that single run of 1/0 will run almost any system. Again that is my rule of thumb. If running one amp around 1000 watts a single 4 gauge run of wire is fine. KIMO @teambassick http://www.teambassick.com
bcbrassard Posted October 31, 2014 Report Posted October 31, 2014 Just because a amplifier doesn't have 0/1 gauge terminals, doesn't mean it can't work with a 4GA to 1/0GA adapter. Maybe he's talking about CCA wire. I agree with this. To have it and not need the power is always better than needing it & not having it. Just my 2 cents.
