Skax Posted October 6, 2014 Report Posted October 6, 2014 ive looked everywhere for a diagram of this could somone please sketch me up a diagram on how to achieve this load I would highly appreciate it thanks in advance 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
rocking.that.eclipse Posted October 6, 2014 Report Posted October 6, 2014 series a pair of coils on a sub then parrallel all 3 subs
Triticum Agricolam Posted October 6, 2014 Report Posted October 6, 2014 series a pair of coils on a sub then parrallel all 3 subs Nope, that would be 2.66 ohms final load. For 0.66 ohms with 4 ohm coils you need to wire all six coils in parallel. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
rocking.that.eclipse Posted October 6, 2014 Report Posted October 6, 2014 series a pair of coils on a sub then parrallel all 3 subs Nope, that would be 2.66 ohms final load. For 0.66 ohms with 4 ohm coils you need to wire all six coils in parallel. Gosh darn it you are right my sir. ohm load for what I said is 8/3 or your 2.66
RainStryke Posted October 6, 2014 Report Posted October 6, 2014 Here ya go http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/3DVC_4-ohm_mono.jpg
Broke_Audio_Addict Posted October 6, 2014 Report Posted October 6, 2014 Here ya go http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/3DVC_4-ohm_mono.jpg Not what he asked for. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
RainStryke Posted October 6, 2014 Report Posted October 6, 2014 Well, this ain't McDonald's and its either that or 6ohm.
islandpride684 Posted October 6, 2014 Report Posted October 6, 2014 Well, this ain't McDonald's and its either that or 6ohm. Tri all ready gave him the answer on how to do it.....two dual 4 ohm sub wired in parallel will bring it down to 1 ohm, then the other dual 4 ohm sub wired in parallel will bring it down to 2 ohms, then wire all three subs in parallel will give it a final load of .66667=.67 Ohms... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Noel989 Posted October 6, 2014 Report Posted October 6, 2014 I just checked at the 12volt 3 dual 4 ohm only options is 2.7 or 6 http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=3&I=42#results To get .6 your coils would have to be d1 http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=3&I=12#results Build Log - http://www.stevemead...-cruiser-el-pt/
REH Posted October 6, 2014 Report Posted October 6, 2014 I just checked at the 12volt 3 dual 4 ohm only options is 2.7 or 6 http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=3&I=42#results To get .6 your coils would have to be d1 http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=3&I=12#results Three dual 4 ohm woofers in parallel is a .67 load. The 12 volt just doesn't offer the all parallel as a choice for a diagram. http://www.rockfordfosgate.com/rftech/woofer_wizard_form.asp?p_parallel_submitted=true&p_search_type=parallel&woofer_qty=3&woofer_imp=2
