Ampere Audio/Fi Sp4 run, Shooting for 30sec at least. Thoughts?
Nice work! how as voltage on that whole run? looked like 12.6 at the end.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I was over 13 for around a minute.
but,
Yup.
It gets low. IMHO, talking to (others) my hair pin turns on at like 10rpm lol. The conventinal wont turn on till around 800rpm.
What will happen is after around 45 seconds, the HP will pull my revs down, down down, where the conv. wont turn on.
Im willing to bet, the conv was doing hardly nothing after around 50 seconds or so.
I did see a 240ish put out, on the hair pin, for around a minute. Again. At idle. :)
Im willing to bet, when i saw the HP do the UPPER number, was when my conv shut down. If ya feel me.
i bet if i put my foot on the gas even a LIL bit, ..... id had seen higher. That said, at idle, holding rest 2mins in, plus. Meh.... not to bad.
Also, this was after 4 or 5 songs at full...... but, reving around 1800.
Meh.... not to bad it dont think. :shrug:
Honestly i think you should pull all the subs and check the tinsel leads. According to everyone else on teh interwebs those things should be cooked or set on Fire
:unknw:
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
:unknw:
:ninja:
thought that was just on Brazilian amps or a new one circulating again?
No idea what kind of run this is, but if you're just idling and figure that on alternator isn't on, that's damn good.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
:unknw:
:ninja:
i have no clue.. i would never run fi subs :unknw:
:ninja:
