Is it normal to get voltage drop on stock alt?
Issues all resolved :D
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
call a mechanic the dropping rpms on downshift does not seem right but i could be wrong,,
Should have specified
The drop doesn't occur due to the downshift. Just when I'm braking to come to a stop the rpms go low around 600 and when it downshifts the rpms hit 500 or so and that's when the slight drop occurs.
Could it just be due to the really low rpm of only 500 and the alt not producing much output at that speed ?
Sub: Sundown Zv4 12
Its probably the low idle even my 270a (5.4) drops quite a bit when I slow down.
You have a ford 5.4? My h/o alt would drop to battery voltage when slowing down and I hit anywhere from 500-650 rpm which was terrible it would dim my lights and everything..
But at idle in park around 700-750 it would sit at 14-14.6 but if I used anything like my lights or heater it would drop pretty low.
Sub: Sundown Zv4 12
double post
Sub: Sundown Zv4 12
Yeah I have the 5,4 in my Expedition. That is not normal though I did have that happen (not as extreme) one time and the battery posts that came with my kinetic were coming loose. Tightened everything back down and the problem went away.
New build coming........
YouTube:http://www.youtube.c...6?feature=guide
Old Build Log: http://www.stevemead...d-on-the-cheap/
Old Screen name: Redrebel66
I think with the stock alt as it doesn't drop below 13.5 it might just be the really low rpms it hits for a split second. Just started noticing it as I installed a volt meter.
Sub: Sundown Zv4 12
what brand H.O. alt did you have?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 3156 Guests (See full list)
