Sundown X15 Box design help
earthlyescape
Take a tad bit off, longer port length always results in lower tunings.. But honestly, audibly your not gonna notice.. Maybe different to the meter but not to you as insignificant a change as it is.. But that all depends on what you want, is this daily or competing?
The correct port displacement is 0.082, in this case the difference is extremely small, one should double check on Torres with boxes where port displacement is significant like very low tuned boxes, small net boxes or walls.
Your box looks ok at 3.8 net if you don't have anymore space and don't want to go into odd shapes, it will likely sound nice is just that you don't get a X for sounding just nice but to get a low end slammer and you are just a little short to get the full blown effect.
Make sure you have a return path for sound waves if you are firing sub and port backwards, that is make sure there's still available airspace around the box.
Looks great. Its amazing the difference a proper enclosure makes!
Builds:
  • Who's Online   1 Member, 0 Anonymous, 510 Guests (See full list)
