noobslayer77 Posted November 1, 2014 Report Posted November 1, 2014 Hey, My voltage drops down to around 13.2, sometimes 12.5 when im banging hard at idle. I read somewhere that immediate voltage drops are due to a bad ground, and that a slow voltage drop is a little more normal if the grounds are good. is this true? should i redo my grounds? 2004 Jeep Liberty Limited 2 13w7s skar 3500 cnf mids (soon) xs batteries
Miguels Posted November 1, 2014 Report Posted November 1, 2014 what alternator do you have. how many batteries do you have. what wire do you have? it all depends. shitty alternator will drop quick. loose wire will cause it. bad batteries will too. too much amp for too little electrical. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
DubNDodge Posted November 1, 2014 Report Posted November 1, 2014 Not always. In my case my engine bogs down enough to be right at the edge of the alternators turn on point. So while driving I don't see any lower than 14.0 and while at idle I'll see 12.8 real quick like. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
alaskanzx5 Posted November 1, 2014 Report Posted November 1, 2014 When I still had my 1500.1bdcp installed with stock elect 0guage front to back and solid grounds I would get sudden volt drop. Could go from 14.8 down to 11.8 and back in a blink of an eye. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Syphlyn Posted November 1, 2014 Report Posted November 1, 2014 Mine will do that too at idle and while driving depending on the song. Some I can play near full tilt while others I can't even play at 50% without it instantly dropping to 12.2-12.5. Saz-2000d stock alt and stock battery. Big three isn't done either yet. Waiting on my mechman 250a elite series alternator. My amp is grounded to my rear seat bracket. I think it's my lack of power rather then the ground. Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
noobslayer77 Posted November 1, 2014 Author Report Posted November 1, 2014 I got a 250 amp alt. Not a singer or mechman. i forget what company. I got a d3400 up front, and 0 gauge all the way around. big 3 was done, but i had to take out the alt to batt wire because i didnt have terminals with enough inputs, However i just ordered some from CNF and can't wait to get em! Got a 1200/1 pushin the subs, gonna add my xp3000 when i get another 1200/1. 2004 Jeep Liberty Limited 2 13w7s skar 3500 cnf mids (soon) xs batteries
noobslayer77 Posted November 1, 2014 Author Report Posted November 1, 2014 i do need to throw my d3400 on a charger, when my car is off it sits at 12.4-12.6 2004 Jeep Liberty Limited 2 13w7s skar 3500 cnf mids (soon) xs batteries
ToNasty Posted November 1, 2014 Report Posted November 1, 2014 You probably have a shit alt and since you dot know the company I doubt you have a HO alt in the first place ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Miguels Posted November 1, 2014 Report Posted November 1, 2014 if you cant remember the name chances are its a shitty alt.. when you get the good shit you never forget.. you said it all when you said its not mechman or singer. not unless its DC how did you ground the rear ground to the amp? if you have no rear battery you are drawing all the amperage through a run of 0 gauge.. even if its rated at 300a per 20 feet you can notice the difference with more runs.. more runs help when you have no battery bank in the rear. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
TRON Posted November 1, 2014 Report Posted November 1, 2014 Cheap Ebay alternator? If thats the case, then get rid of it. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
