tburt915 Posted November 7, 2014 Report Posted November 7, 2014 I have 2 12in FI BLs in a 5 cubic foot box tuned to 32 hz. I have 14 sq inches of port per cube. I am running my new BLs on a sundown saz2500 at 1 ohm. I am very disappointed in the outcome of this setup. I had 2 12in FI SSDs in the same box ran off a bit less power, around 2000, and they were louder at every frequency but the low 30s. For some reason, I peak at 30hz where i was expecting to peak in the mid to high 30s. I have had a single 12in FI BL before and it seemed to not like to go much under 34hz. Im confused as to why they are peaking so low?
Joe X Posted November 7, 2014 Report Posted November 7, 2014 Pics of the install, sketch of the box, and how you tested, just by ear or what you used.
bcbrassard Posted November 7, 2014 Report Posted November 7, 2014 Joe X is on the case, he'll give you some killer insight if you give him all the info he asks for.
tburt915 Posted November 8, 2014 Author Report Posted November 8, 2014 I get some pics up asap. The box is 32x15.5x27.5 with a double baffle and a center port that is 4.5 in wide
tburt915 Posted November 8, 2014 Author Report Posted November 8, 2014 tested by ear but its very clear that they do not hit 40 hz well at all.
Skullz Posted November 8, 2014 Report Posted November 8, 2014 Are the subs new by chance? If the subs are new you'll need to break them in to get the most out of them which might explain why your ssds's were louder right now than the BL's 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
DTS909 Posted November 8, 2014 Report Posted November 8, 2014 Ran to my car to check a 40 hz tone. I got almost the same setup and its slams. Need those pics and more info. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
tburt915 Posted November 9, 2014 Author Report Posted November 9, 2014 Subs are about one month old. Also in the system I have Pioneer 80prs Rockford fosgate rf bld processor Rockford 4 channel 250w speaker amp Sundown SAZ2500 v2 shruiken bt60 60ah battery xs power d3400 67 ah battery RE audio 0 gauge Sky high audio big 3 with 0 gauge 180 amp aftermarket alternator
Aj11 Posted November 9, 2014 Report Posted November 9, 2014 i wanna say you broke your box. i had the same thing happen to me 5 weeks ago. 2 days before a show i turned my system up and it had lost all the power. no highs..Lil lows. while i was looking for electrical issues i found the side of my box Was separating. check your box, play at half volume and feel your box. check for leaks and flex. if everything was fine before you switched subs, either you wired the ohm higher then planned or your box is leaking jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
cloud77 Posted November 9, 2014 Report Posted November 9, 2014 You didn't get an SPL machined gap did you? 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
