2 amps, 1 woofer
MatthewBigBossWilliams
Also going to have to worry about gain matching the two amps, cause if they put out even slightly different power levels you're going to run into issues quickly.
The CC and DD were mailed to me and are enroute. I am just getting an early start on set up so all I have to do is gain match and play
one amp per coil @ 1ohm gain matched with the CC1 after you DD1 one of the amps
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
Just checking. Skipping that step even if everything is wired right is going to cause you serious heartburn.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
What if I just set the volume up halfway on both amps. Still a bad idea?
Volume? I hope you're not referring to the gain as a "volume" because those are definitely not the same.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I meant the gain on the amp. I was thinking about puting that half way up on both amps and trying it out that way.
That is a very bad idea
1. because most of the time the gains do not need to be set that high
2. If you do that you'll possibly clip the hell out of the sub
3. I'd be surprised if you could even get both of them in the exact same position
Just wait for the DD-1 and CC-1 to get to you. It's better to be safe than sorry, especially when you dealing with expensive equipment.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   1 Member, 0 Anonymous, 1490 Guests (See full list)
