alt shutting off at idle?
hey guys. i just got done installing my mike singer 250 amp alt and xs power d3400 in my mazda 3 today. voltage is great except for at idle
voltage will be 14.2 or so while driving as soon as i stop its like the alt shuts off and my voltage drops to 12.7 roughly..
fans slow down which is annoying becuase winter is coming, but all my lights dim also. the second i rev a bit voltage drops right back up until idle speed again. lights jump back up and i can physically hear the fan speed up on my heater!!
any help would be greatly appreciated..
car is a 2007 mazda 3 sedan. 2.3L
ill work on uploading some videos
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
alternator turn on is prolly to high for ur application, what is the engine rpm of ur idle? do you know crank pulley size?
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
idle is about 700 rpms. and no i dont know the crank pulley size
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
its bc your alt spins too slow. One solution is getting a SLIGHTLY smaller pulley.. which is also called an overdrive pulley. Im sure the pulley you have is smaller than factory, but.. Id hit up Mike asap.
This even smaller pulley will increase the alternator's rotor assembly rpm. In return, your alt will turn on and charge at idle. Now, keep in mind that there will be less belt contact (smaller area) with the alt's pulley... But priorities..
Anyway, shoot Mike a message. He wont leave you hanging.
Maybe see whats good with efFlako. Iirc he has a Singer in a Mazda 3.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Idle speed is below the turn on speed for the alt.
Options are:
Ignore it
New/different alt
Raise idle, which will reduce fuel economy
Smaller alt pulley, which has the potential of inducing/intensifying belt slip
Larger crank pulley: No belt slip problem, but other components on the belt will wear slightly faster. Also tend to be pricey. FWIW that's the route I took for my own vehicle
talk to company owner and get it figured out you paid for an alt that charges at idle so thats what ya should be getting for your money., if u have an aftermarket underdrive crank pulley on ur car then its prolly an issue of yours
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Apparently the automatics idle higher the manual. And the guy I bought it off of has a automatic
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
I had a alt that would turn off at idle I would just rev it or put the car in neutral
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
I don't wanna sit there and rev every light especially because my commute is all city driving
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
