Amplifier Trouble Shooting Issues
Dominique Jacob Redlin
Thank you! Couldn't figure that one out.
2000 Blazer LS
Head Unit- Pioneer DEH-X6600BT
Speakers- 4 x Pioneer TS-A1685R
Amplifiers- Autotek Mean Machine M4000.1
- Pyramid America 2000 watts
Power Caps- Boss Cap 8.0 Farad
8 Gauge Ground and Power wire
Subwookers- Two 15 inch Earthquake Tremor-X154
- Two 10 inch Boss P106DVC
Here's another question. When I turn my stereo up the highest that it will let me go without cutting the subs is 45/60 or 75% is this like natural or...? I realize my stereo shouldn't go louder than 75% and that's where I tune everything but is it bad for them to cut at this level or should they be able to withstand higher volumes?
2000 Blazer LS
You are supposed to set your amp gain based on your head units maximum un distorted output.
You need an oscope or a dd1 to tell you that. Hopefully a your deck is clean higher than 45/60
So it all works fine till you turn the head unit past 45?
faulty distribution block? please take your car to a shop to have this looked at before you burn your car to the ground.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Faulty distribution block? What's there not to get? By replacing the p.o.s. block with a different more efficient one I solved my problem. My subs will completely shut off after 45 and then come back on after I've turned it down a bit. I don't usually go over 45 in the first place
2000 Blazer LS
yes
2000 Blazer LS
my statement stands. take your car somewhere before you burn it dkwn
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I'm with n8ball man. Take your car somewhere before it burns to the ground.
Instead of replacing the "pos" distribution block maybe replace your pos equipment. Cheap stuffs ends up costing more in the long run. I learned everything I know from online forums and the likes about car audio.
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
I read the first post and thought this was a troll thread, but I'm starting to think it's serious! I will not touch this with a 10 foot pole.
OP, please find someone who knows what they're doing to check and install everything and for the love of God buy yourself a fire extinguisher and some bolt cutters so you can snip wires and put out the fire when you see smoke.
This isn't a joke and it's not us being mean. There's simply too much wrong here to address and the more considerate and thoughtful members don't want to give you "advice" because they know they'll feel bad when you burn your car to the ground or start blowing up equipment.
If things are "cutting out" something is dreadfully wrong. Seriously, remove the power cable from the battery immediately and take it to a professional.
  • Who's Online   0 Members, 0 Anonymous, 421 Guests (See full list)
