4 15s on two amps in full size tahoe
sicrides6
Needing recommendation on best type of box for 4 15s in a 97 Tahoe these are dual 4s and will be running on two amps 2 subs per amp. Would it be possible to do in a slot port. I am currently running 2 in a slot tuned to 35. Would I be able to build the exact enclosure and just double the size of w-h-l and double the port size as well. Kinda a noob. All feed back is appreciated
All Tahoe's are full size, lol, all good man. Yes, you can have all 4 in one box with a slot port and in 1 common chamber. Just doubling all dimensions will not be right. Someone else will chime in with what exactly you should do as I am no box expert. Also, make sure you gain match those two sub amps.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
This is mine, 4 - 15", slot port, tahoe, etc. more vids. on my channel I think of this set up
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Best box type would be ported. Wall would be better :)
Just the math part of this....... Doubling one dimension in your LxWxH measurement will double the volume of the box.
Are you going from 2 subs to 4 of the same?
A box designer will need sub specs and your max possible dimensions.
Example: pretend you just doubled dimensions....will if your box is 20" tall now it would then be 40" tall....that would be crazy silly when it's mere inches under your head liner. Just an FYI
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
With the correct tuning, you can fit 4 15s below the windowline and sound great. I've seen it done many times.
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
