High power handling Non PA highs
nocturnalrites101
The amp you recommended is a two channel so I'm assuming passive. That kind of money you have a ton of options. I would go to partsexpress and build a custom 3 way seat. They have some midrange and tweeters that could take that wattage. Keep in mind if you go this route they will most likely 8 ohms so you will effectively cut the amp wattage in half. Your also going to lose some power through the crossovers. This means you could run lower power comps. More safely. With the budget provided I would go morel. The midbass I would use is a 9" but they have smaller ones...
Midbass
http://www.parts-express.com/morel-caw-938-9-cast-frame-woofer--297-086
Dome midrange
http://www.parts-express.com/morel-mdm-55-2-1-8-soft-dome-midrange--287-020
Tweeters
http://www.parts-express.com/morel-et-338-1-1-8-soft-dome-tweeter-matched-pair--277-070
This with a couple custom passive x-overs will be under budget and sound pretty awesome. That being said image dynamics, jl evolution comps, cdt audio and others will work on that power and be much cheaper.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
http://www.parts-express.com/morel-st-1108-supreme-1-1-8-soft-dome-tweeter-pair--277-094
what about these instead though i wouldnt wanna run that amp at 8 ohms
Holy shit thats a lot $ for tweeters!
What vehicle are we working with here ???
How detailed is your install ???
You have locations for a 3 way setup ???
Not if you keep your interior stock ...
You plan to build kick panels ???
  • Who's Online   1 Member, 0 Anonymous, 762 Guests (See full list)
