#puntodemobuild +162dB 8x15" 60000W DD Audio Soundigital Ground Zero Winston Lithium
This thread deserves so much more comments!
A lot of fun :D
One thing I miss though is an english commentary video on the setup, where you point to the "cool" solutions, mishaps, and unique things about the work. I know there are plenty.
ie: More commentary !
Cheers,
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
Thanks! :)
I can write english but speaking - that's different story. Pronouncing is too hard for me. Almost as hard as mandatory swedish - "Jag heter Joni, vad heter du?" :D
I may add subtitles for my videos if/when I'm popular enough :lol:
A lot of fun :D
Cheers,
First video of the new system, needs more power :D
SPL scores :)
Closed:
Door open:
Kick:
I bought some used Winston 90ah lithium cells.
15042134_10206246271750713_2587159207566
Here's a comparison vid with agm-batteries. Cells were out of balance in the vid, much better now.
Here's a vid after balancing:
Had 5x Optima 75ah & NSB Red 100ft before, now 3x Optima 75Ah & 3x Winston 90Ah.
About 0,4v less voltage drop and weights less than half compared to agms :)
First tests:
Lithium AND another M4a.......?!?!?!? no room? time for bigger vehicle?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Yes, 24x Winston 90Ah 3,2V cells = 540Ah 12v. More Ah than before (475Ah) and less than half of weight, 75kg vs 166kg :)
I'll try to fit all those amps to roof, there should be enough space :D
Hatch has seen better days :D
Glass is loose from below and hatch is cracked badly, some welding is required :devil:
Then this happened :D
15326289_10206376852095140_8767316064794
Had to test spl without rear window, almost 150db to windshield :D
Couple meters of flat steel bar and few pieces of steel pipe to reinforce the hatch, one day of welding :D
Next I glued the window:
15493785_10206406429594559_8751753253555
Still there, at least a week after :D
Lithium to engine bay also. Short out protection is missing from the pic. There will be 24x 3,2v 90ah Winston cells in summer :D
15440575_10206463472700601_8386685402572
All amplifiers will be DD Audio before summer, this SS4a will be for midranges and highs :)
15626470_1057840937695987_19262089758818
Jeez I like the changes, reinforced welded hatch! 150 db with no rear window?!?! damn man..... ALL DD amps... Lithium underhood...always enjoy following your build
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
  • Who's Online   1 Member, 0 Anonymous, 1084 Guests (See full list)
